region free dvd software
Discussion in 'Desktop & Laptop Computers Forum' started by themadhippy, Aug 18, 2002.
  1. themadhippy
    themadhippy
    dont know if this has already been posted here but found this site that maybe usefull for anyone wishing to change there pc's dvd to region free.was a bit worried after reading the warnings that if it failed i'd be left with a duff dvd,but it worked first time without any proplems
  2. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    I need help i have a MEDION pc and my DVD-Rom has no name it just says this,
    IDE DVD-ROM 16X
    how do i find the Firmware if i cant find out the name of my Drive???
  3. themadhippy
    themadhippy
    i had the same proplem,nothing on the front of the drive and windows reporting it as an ide dvd rom,in the end i took the drive out,luckily there was a sticker on the top with the serial and model number along with a manufacter,a quick search in goggle for the manufacter confirmed i was on the right track
  4. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    I tried to flash my drive to make it region free but failed :( luckily it still works though, I may have to try again.
  5. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    themadhippy
    I have my patch, but could you tell me what to do with it, I could not find any instructions on how to flash my drive, does it involve putting it on a floppy and booting from that?
    :confused:
  6. Zone
    Zone
    Jun 24, 2001
    6,813
    Barnsley
    +2,573
  7. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    If you need to find what firmware your dvd drive is using, try cdinfo its a small little prog. and gives loads of info on you drive.
    Spunky
  8. themadhippy
    themadhippy
    Timh,i downloaded uflash and the relevent bin file, from http://www.firmware.fr.st/ unzipped them to the root on c:\ ,rebooted the machine with a windows start up disc and ran uflash from the c:\ promt and selected the relivent bin file,less than a minute later job done.not sure if this will work on other manufacters dvd roms but certainly worked for mine.
    did try useing various hardware detection utilitys but they all gave the same result, ide 16x dvd rom :confused: ,in the end it was easier to take the drive out
  9. Zone
    Zone
    Jun 24, 2001
    6,813
    Barnsley
    +2,573
    Timh
    Belarc should advise make and model, its a start! Then as I'm sure you (as everyone else does) do a search on Google for further help!
    Si
