Region Free DVD playback under MCE Play DVD
Discussion in 'Microsoft Windows' started by dUnKle, Jun 20, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    14,923
    +2,058
    Just recived Hostage (R1) and tried to play it via the Watch DVD option under MCE to be met by the "cannot play due to region ......" message
    However I have DVD Region Free installed and under TheaterTek and the like it plays fine - but not under MCE
    Is there anyway it can be corrected ?
  2. Rambles
    Rambles
    Jul 14, 2004
    7,707
    UK
    +909
    That's odd - can you change the firmware on your DVD drive to be region free?
    I have a Lite On Drive and have a little firmware app that lets me change the region as many times as I want to.
  3. WBC
    WBC
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    AnyDVD from Slysoft is fully compatible with MCE.
  5. dUnKle
    dUnKle
    Jan 1, 2001
    14,923
    +2,058
    thanks
    I will give that a go
  6. DaveP
    DaveP
    ISTR that it needs to know the applications that you use to play DVDs. If you have had the software some time it probably isn't aware of MC.
    You have to add the program in. I can't remember for sure but it's something like eshell.exe
    Dave
