Region 5 + 6 suppliers?
Discussion in 'Blu-ray & DVD discs' started by Cowbuster, May 3, 2002.
  1. Cowbuster
    Cowbuster
    May 3, 2002
    40
    Does anyone know of any R 5 + 6 suppliers because so far I've had no luck finding any. This may have already been asked somewhere along the line but I'm new so go easy please!!
  2. Der_Pobman
    Der_Pobman
    Hi I live in Moscow much of the time and so can get R5 Russian films. If there is a particular film you are interested in I might be able to help you, ie buy it for you, but this would take a while and I would not want to do it very often. They cost between 700-900 roubles (25-30 dollars) each.
    I can highly recommend BRAT (Brother) and to a lesser extent BRAT2 (Brother 2). In fact I could list a number of older soviet films which all have their merits.
    However they only sell Russian and US films in R5, you cant really get Indian for instance.
    If somebody can suggest a European/US based company that sells these regions I would find it useful too.
    Regards
    Der Pobman
