Region 3 Widescreen discs displaying as 4:3
Discussion in 'Movie Forum' started by russ123, Mar 27, 2006.
  1. russ123
    russ123
    Jul 31, 2004
    841
    46
    South Of The River
    +119
    Not sure if this is a common problem or not but I have several region 3 discs that are clearly sold and labelled as widescreen editions that when I play em back on my Denon 2910 and Infocus 4805 pj show up as 4:3 aspect ratio:thumbsdow . I always go in and change the display setting from native to widescreen and I think I then get an actual w/s image rather than stretched 4:3. Anyone else come across this? Could not find anything via search. Had it on Batman Begins and the second and third Matrix sets.
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,137
    Bristol
    +9,881
    Where did you get the discs from? as I have never had a problem with any of my R3 releases, if they have been listed as widescreen then that is what they have been.
  3. russ123
    russ123
    Jul 31, 2004
    841
    46
    South Of The River
    +119
    All my region 3 will come from CD Wow. The listing, the case and the disc itself all show as widescreen. I dont notice the image as stretched when I change to widescreen (it definitely does not display more information though). Not sure if it is all my Region 3, will have to check, but I noticed it again this w/e as I watched the Matrix trilogy.
  4. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,067
    +170
    Do you mean your projector is just not autoswitching with ntsc discs?
    I have to switch mine over myself - I had the R3 Matrix 3 (2 disc) from cdwow and it was 2.35 Anamorphic
  5. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    I've just got some region 3 ntsc discs from cd wow today. Will do a quick check and let you know what happens.
    Ray
    Edit: Just checked Batman Begins, Wallace and Gromit and Harry Potter - Goblet of Fire. All region 3, all displayed correctly and projector reporting ntsc 60hz. Is your dvd player set up for ntsc ok ?
  6. russ123
    russ123
    Jul 31, 2004
    841
    46
    South Of The River
    +119
    Thanks both, I'll check the NTSC settings on both. Never noticed it on Region 1 though which is weird. Popped the discs in my other dvd connected to a tv and they come up w/s fine so must be something in the setup.
  7. russ123
    russ123
    Jul 31, 2004
    841
    46
    South Of The River
    +119
    Toggling the NTSC/PAL option on the dvd resolved it. Thought it would do this automatically but obviously not. Thanks all:thumbsup:
