Region 1 Subtitle Problems
Discussion in 'Movie Forum' started by waterhousej, Jul 27, 2003.
  1. waterhousej
    waterhousej
    Mar 9, 2003
    30
    I have recently bought some Region 1 DVD's from the USA and am experiencing problems removing the subtitles on some of the films. The discs are being played through a multi-region Marantz DV4300 which plays most Region 1 discs without problems. Has anyone had the same problem or know of a fix?
    Jamie
