Region 1 or Region 2???
Discussion in 'Movie Forum' started by gpedder, Aug 8, 2003.
  1. gpedder
    gpedder
    Jul 5, 2003
    24
    4
    luton, UK
    Now that most region 2 disks live up to their Region 1 counterparts I was wondering.
    What is the best choice for quality on a prog scan setup?
    I like the fact that the runtime is the same on NTSC whereas PAL
    tranfers are sped up to 25fps. Am I losing anything going for Region 1?? I noticed a massive improvement going progressive.
  2. Ricky27
    Ricky27
    Feb 8, 2002
    1,866
    Norwich
    +204
    There are loads of threads on this very subject, lots of info if you use the search function.
  3. gpedder
    gpedder
    Jul 5, 2003
    24
    4
    luton, UK
