region 1 NTSC on RGB SCART?
Discussion in 'Projectors, Screens & Video Processors' started by ragegames, Apr 14, 2001.
  1. ragegames
    ragegames
    Apologies for the slight off-topicness, but this forum seemed to have more stuff on colour standards etc. than the others.
    I have just ordered a region-modified Sony 735 DVD player to replace my aging Samsung 807(so I can go from composite and RGB-SCART to S-video and component outputs for my PLV-30 is the main reason, though its started to have trouble with a few "problem" discs nowadays)
    My question was whether my main TV- which will display PAL & PAL60, but not pure NTSC, will run OK on the RGB SCART connection when playing a region 1 disc, which the Sony outputs as NTSC. Its my understanding that "NTSC" is only applicable to the Composite (and possibly S-video) outputs so as long as the TV copes with a 60Hz picture I should be OK- is this correct?
    Please advise as I've just ordered the player and I have a short time to cancel before they can do deliveries after Easter
    Peter
  2. Matty N
    Matty N
    I have a multistandard TV and the Sony DVD you refer to having ordered. When using a RGB connection and a R1 print the TV switches to NTSC, it shows the usual problems if I try and switch it back again. Hope that helps
    matt
  3. Mr A
    Mr A
    Hello,
    I use a Sony 735 with Scart set to RGB to feed a PAL only TV! I have no problems playing region 1 discs, so you should be OK.
    Hope it helps
