Regarding Pioneer dv575
Discussion in 'Blu-ray & DVD Players & Recorders' started by chrish16, Jul 19, 2004.
  1. chrish16
    chrish16
    Jan 31, 2004
    418
    County Durham
    +19
    My equipment:
    Panasonic TX-32PD30
    Yamaha RX-V440RDS
    Mission M5s 5.1 speakers
    Toshiba SD-220
    After reading your excellent review on the Pioneer DV575 DVD player i am considering upgrading my DVD player to this model. My first question is does the performance of the dv575 match that of the Toshiba sd-220?
    I have read from various sources that the Panasonic TX-32PD30 does not have PAL progressive scan on some of the batches; is this true? Does it have NTSC progressive scan?
    In the August '04 issue you state that the Toshiba sd-240 has full progressive scan; what do you mean by full progressive scan?
    My most important question is will the Yamaha RX-V440RDS be capable of playing SACD and DVD Audio to its full potential in terms of high quality performance regarding DACs and frequencies?
    What interconnects would you recommend for SACD and DVD Audio on a budget?
    Regards
