Regarding connections from Sony DAVs500 to Hitachi
Discussion in 'Sony TVs Forum' started by MARLEYMAN, Jun 3, 2003.
  1. MARLEYMAN
    MARLEYMAN
    I know I have to get an SVideo - Scart connection, but have seen that Svideo + 2 Phono - Scart leads exist. Would anyone know which of these I will need please ?
  2. RichardJ
    RichardJ
    Jan 27, 2003
    Shropshire
    +6
    You will only need the SVideo + 2 Phono if you intend to use the speakers on the Hitachi. If you intend to only use the speakers on your DAVs500 then a simple SVideo to scart cable is all you need.
  3. cadmeister
    cadmeister
    Nov 12, 2002
    107
    19
    Milton Keynes, UK
    Since you will be using the DAV for the audio component then all you need is acable to get the video from the DAV to the display. Thus all you need is a plain old SVIDEO to SCART cable
    Hope this helps ;-)
  4. MARLEYMAN
    MARLEYMAN
    ooooohhhhhh Cadmeister aren't you formal
  5. MARLEYMAN
    MARLEYMAN
    Also curious as to whether this will allow me to utilise the facility the Hitachi has for the TV's speakers to be used as the centre speaker in the 5.1 system ??
  6. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    Apparently the centre speaker option is disapointing but no you cannot via the scart but only by connecting the centre speaker line output on your amplifier (if there is one) to the line audio inputs on the Hitachi AV box.
