Rega Planar 3 Belly up?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by alfablue, Jul 2, 2004.
  1. alfablue
    alfablue
    Aug 16, 2002
    287
    19
    I changed the belt on my P3 for a new one (an original Rega part), just because it was a bit old. Since the change the speed has been up the spout, and merely the drag of the stylus slows it right down. I initially suspected maybe a little "finger" oil on the belt / spindle so i cleaned everything, no joy, then I replaced the old belt, no improvement. :thumbsdow
    The belt doesn't appear to be slipping, so is my motor :censored: ?
    The fact that this coincided with the belt change is weird - I guess its that old adage - if it aint broke... :nono:
    The P3 was manufactured in 1995, and is "low mileage"
    I don't understand why the motor is acting this way rather than failing completely - or could it be another component? Any suggestions?
    I know I can upgrade the motor for £85, but I want to be sure about the cause first.
    Many thanks
  2. nikyzf
    nikyzf
    Is it possible you've got oil on the motor pulley? Give everything a good clean, then put some French chalk/talculm powder on the belt (either one). If still no good, contact Rega, or if you bought it new from a dealer, see if they have any ideas.
    Another thought- is the mains connection OK? Could you have loosened a plug at some point?
  3. Warpaint
    Warpaint
    Jul 26, 2003
    601
    28
    Edinburgh
    +62
    It's also possible that the motor pulley has become loose and is slipping.
    Try holding the pulley when the motor is switched on (for a short time only). You should be able to tell if the motor still rotates and the pulley slips.
    I think the pulley was originally a friction fit. If it is loose then take it off completely, clean the pulley and the spindle with meths or similar and apply a small blob of araldite to the pulley hole. Refit the pulley and leave it until the araldite sets.
    Good luck.
  4. alfablue
    alfablue
    Aug 16, 2002
    287
    19
    Thanks Guys
    Tried all the above, and I think Warpaint hit the nail on the head! The pulley just came off in my hand (as they say). Just sorting out the araldite now! Maybe the forum saved me £85! Will let you know.
    Thanks again
  5. alfablue
    alfablue
    Aug 16, 2002
    287
    19
    Result:
    While I was having a "dry run" reassembling the pulley on the motor spindle I found it was a very firm fit (required gentle use of a vice to seat the pulley). The result was so good that I didn't need to reassemble with Araldite, and it now works a treat. It is amazing that it had eventually worked loose when it is such a tight fit - but there you are.
    Looking at the assembly / motor mounting I can see how much the deck would benefit from the upgrade, so I will get one eventually.
    Anyway - all sorted! Many thanks for your help and for replying to my original message.
    Regards
    Richard
