Rega Brio or used alternative
stumck219
I am looking for amp recommendations, I am considering a new Rega Brio but am wondering if there might be some used alternatives offering more bang for my buck.
The amp will be used for streaming from a Nord easy stream connect Dac with Wharfedale Reva 2 speakers.
Any recommendations would be appreciated
Paul7777x
It’s hard to see the Brio being anything but a top class buy for the Revas.
It’s already a legendary amp. I think I’d go there in your case.
If, however, your budget is a bit flexible upwards, then you should seriously consider this quite superb amp.
Originally £1600 and will be considered a bit overkill for your speakers.
But it is all the amp you’ll ever need and you’ll certainly be getting the best possible sound from your Revas.
Paul7777x
Then there’s this bad boy...
Quite a superb ‘budget’ amp. I loved mine years ago.
This will also be considered a bit excessive for your speakers, but there is nothing wrong with that at all.
Both of the amps I’ve mentioned will happily drive speakers into the £2000 plus range should you ever wish to upgrade.
Paul7777x
And... last one, I promise.
Again a top class bargain.
stumck219
Thank you very much for taking the time to make these suggestions. The Primare seems very interesting, not a brand I know alot about but I will definitely have a read up on that.
