Rega Brio Bi-Amp?
jona1971
I bought my Setup 10 years ago and its been great ever since.
Now i've been messing about on e-bay and I have ended up with an extra Rega Brio Amp to match the one I have already. This is because my original salesman said something about 2 being better than one - Bi-Amping etc. I wasn't listening at the time but here we are.
Can someone please explain which lead goes where?
Many thanks in advance...:)
larkone
I am afraid you cannot bi-amp with a Rega Brio as it does not have any pre-amp outputs to connect to the second amp
sergiup
But I believe you can split the pre-amp input with some basic RCA splitters and do it that way - use something like this maybe?
The trouble is you can only really do this if you use the Brio as a power amp on a fixed (ideally unity) gain, anything else will require re-matching levels etc and would just be a massive PITA.
jona1971
is that from the source into 2 amps? for each source?
(If that's so I'll have a lot of spare expensive interconnects.)
NB. the second amp is a Brio 3 with Pre out / Power in, the original amp is a Brio. Er, does that help?
Thanks for putting up with my questions...
sergiup
Oh right, so you actually have two different amps? That's not indicated for bi-amping, which would actually involve two identical amps...
larkone
I checked the specs and the Rega Brio 3 does not seem to have a pre-amp out or power in. It has a tape in/out which is not the same function.
The Mira 3 has a pre-amp out, is it that one that you have?
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
