Refresh rates question...
Discussion in 'LCD & LED LCD TVs' started by PhilipH, Oct 26, 2004.
  1. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Think I've finally decided on a Sharp LC32GA4E - it has a proper 16:9 panel, it has all the inputs I need and it has serial port control that I know does what I need it to do. (www.av-sales.co.uk have them listed for about £1,530)
    Thing is, the manual states that it handles 1366 x 768 pixels @ 60Hz - anyone know if you can refresh at a lower rate (50Hz) so that you don't get juddery pans on PAL DVDs? What's the usual workaround that people do for this?
    Phil
  2. jgrg
    jgrg
    Oct 19, 2004
    547
    28
    Cambridge
    +33
    Sounds like a great price, but I think the DVI input is intended for computer input only, and may not work with DVD players.
    James
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I think Phil uses a PC? This is a common problem, 50Hz is likely not possible. 75Hz would be worth a try, that will be smooth with pal. We have to do this with Fujitsu plasmas run with scalers, they won't take the same 1366/768 at 50Hz They do display, but the picture is offset about 40% to the right. 75Hz is fine with them, I'll ask a man who knows in the am. Ps that is an amazing price, well below my buy in price.
  4. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I have conected a HDMI DVD player to the GD1E version via an HDMI to DVI-D cable. The EDID indicates best resolution of 1024x768 for 50Hz material, but it worked fine at 720p (1280x768) although I could not get 1080i (1920x1080i) to work. Sharp have acknowledged this to be an issue with some sources.
    I believe that the GA4E and the GD1E are fairly closely related. Certainly with the GA3E (bottom speakers) version, DVI operation is documented to be the same as the GD1E. My understanding is that the only difference between the GA4E and GA3E are the speakers are at the side.
    -Ian
  5. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Correctamundo my metal bodied paranoid friend!
    Managed to get the serial protocols for this unit - as well as the engineer code which stops it turning off the serial port circuitry when it's powered off so that you can then power it on again via serial commands.
    A mate (SofaSpud) bought one of these recently and really rates it.
    Phil
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    My favourite LCD panel too. Only the Pansonic 42PHD7 will stop me having one. That has a wireless presentation video card, and I'm a sucker for gadgets. BTW the projection screen is great with the X10 switch!
  7. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Yup - 3E has speakers on the bottom, 4E has them on the side...
    ...cool - so it will handle 50Hz via DVI - *SUPERB*!!!!
    Phil
  8. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Cartainly at 1280x768 then you can use the zoom functions. However, the jury is out for 1366x768@50.
  9. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Unfortunately I don't have the space for a 42"...
    ...well OK - the *WIFE* says I don't have the space for a 42"!
    Actually I also want higher res than 848 x 480 too - I'm trying to write my own HTPC front end now that Meedio etc. don't *QUITE* do what I want or work as simply as I need.
    Phil
  10. APC
    APC
    Sorry for going OT, but I have a couple of questions about the Sharp LC-32GA4E (ie. the one with the side speakers).
    1. Is it meant to be used with *or* without the side speakers? The manual asks you to attach them, but is this just as preparation, or am I right in presuming that the set is designed to look OK (i.e. properly 'finished', with no scre holes showing etc) with them off? I don't need the speakers.
    2. This sounds daft, but what are the 'feet' like on the front of the stand? Do they have rubber cushions underneath or are they flat?
    Thanks.
  11. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    I'm planning to use it without speakers too ... as far as I can tell from looking at a 30" unit the other weekend then the side speakers (and bottom speakers) can be fitted or left off as required. The unit I looked at looked fine without them.
    Phil
  12. APC
    APC
    Hey, many thanks for the reply. :thumbsup:
    Now if only I knew about those damn 'feet' :rolleyes:
    Have you seen any info on typical response time of this screen. Can't find any info anywhere. :rolleyes:
  13. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    16 ms. :cool:
  14. tonyoevans
    tonyoevans
    Nov 6, 2001
    139
    28
    Hagley
    +21
    Unbeatable have the Sharp LC32GA4E listed as £1,243.16 now. Very tempted
  15. jgrg
    jgrg
    Oct 19, 2004
    547
    28
    Cambridge
    +33
    Hi Tony,
    Sure that you mean Unbeatable? They have the 26 inch version at £1,123.99, and the LC32GA4E at £1,999.99.
    James
  16. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Cheapest I've found so far was Empire Direct... £1,200 and a bit.
    Phil
