Reflective paint
Discussion in 'Projectors, Screens & Video Processors' started by smallangryboy, May 8, 2003.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Anyone know if there are any paint products that can be used to create a reflective screen for an LCD projector, and if so where can they be found ?
    So instead of using a roll down screen, one wall of the room is painted to project an image onto.
  2. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    Here you goo.
    Others have great success with regular Dulux Icestorm paint :)
    -- Jon
  3. stevelup
    stevelup
    Aug 13, 2002
    6,507
    Swindon
    +1,080
    Are you sure you want a reflective screen for an LCD projector. High gain screens often get worse hot-spotting and accentuate the poor C/R of most LCD projectors. They are also affected more by ambient light.
    You probably just want a light grey screen (Dulux Icestorm 5 or 6)
    Regards,
    Steve
  4. Kase
    Kase
    A reflective paint, rather than something like silk vinyl, will have tiny flakes of aluminium in it, which cause the sparkly effect when you paint them on. However, the flakes will align in random directions and simply create 'snow' on your picture with thousands of tiny hot spots, unlike a proper reflective screen which I believe uses tiny beads that act similar to cats eyes, by reflecting the light all in the same direction (i.e. back at the viewer) rather than scattering it all over the place.
  5. Anders_UK
    Anders_UK
    Don't get too hung up on all the marketing crap that goes with screens. You won't be able to tell the difference a great deal anyway - unless it is really badly done.
    A normal matt paint - with a hint of grey to improve contrast will be fine.
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,152
    UK.
    +2,671
    Or maybe white blackout cloth stretched over a frame. That's what I used for over two years until I needed some extra gain.
    The blackout cloth is around £5 (or less) per linear meter, and a frame will cost just a few quid for the wood.
    Be carefull with the paint - too refelctive will give a hotspot in the middle.
    If it has to be paint, I'll second the Icestorm 5 or 6 vote though. :)
    Gary
  7. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    Where does one get blackout cloth ?
  8. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,152
    UK.
    +2,671
    You can get blackout cloth from most good curtain shops or haberdashers (sp?).
    There are various colours it seems, but look for the whitest one. It'll be a white cloth on one side, and a white or off-white vinyl on the other.
    It's used to hang behind curtains to act as a light block.
    Gary.
  9. fazer600
    fazer600
    May 10, 2003
    28
    3
    Caterham, Surrey
    +5
    Or pop into Ikea and pick up a white blackout blind for £20 200cm x 195 cm. Works brilliantly with my AE100.
  10. xander
    xander
    Jul 1, 2002
    130
    New Zealand
    I've had very good results with Silk and Satin interior water based paints (gives a nice bright picture, better than on flat paint, imo). I've settled on Dulux 474 (they don't know about Ice Storm down under) after experimenting with a few colors. The biggest problem however is to apply the paint with an even sheen. Spraying is the best but causes too much of a mess if you have to paint this in-situ. I've purchased Dulux semi-gloss this week, together with Floetrol (spelling?) to help in the smooth application. I will be rolling it on.
