ReEncoding HD .ts streams... help!
Discussion in 'General TV Discussions Forum' started by Wilster, May 24, 2004.
  1. Wilster
    Wilster
    I've found some sample .ts files in 720p and 1080i, and i figure with the size of the .ts movies Im going to want to reencode them to wm9 to squeeze them on to one dvd if possible - much easier to watch that way! Do any of you know how to do this?
    I've downloaded the WM9 encoder pack from MS, which cannot open transport streams. In fact the only thing it seems to open without crashing is files already in wm9! Nevermind I though, I'll fix that later, so I tried to convert the .ts to a .mpg with pvastrumento, but it crashes too. I've googled for a guide as well and had no luck at all... help please!!!
  2. Goose74
    Goose74
    Sep 24, 2002
    826
    Romsey
    +12
    I would check out the HDTV forum thread at supronoca.org
  3. dgc
    dgc
    May 1, 2003
    216
  4. Wilster
    Wilster
    Thanks for the links, Ill give it a go tonight :)
