reduced noise
t1m103
hi ive managed to severly reduce the noise from the box by removing the tray that holds the hard drive in and cutting about 3 mm from the bottom of it around the fan hole,now the tray is sitting clear of the metal box and the fan rubber mounts are just touching the metal casing instead,where as before the square fan hole was touching the metal casing causing it to make a noise.
