Redsnapper good for 70-300
BRIGHTY
Hi guys.
I'm looking at getting myself a tripod to go with my nikon D3100. Lenses i have are the kit 18-55, 35 prime and 70-300 vr. I'm looking at the redsnapper 3 section with a ball head. Firstly is the redsnapper man enough for the 70-300 and also which ball head can i get away with, the small cheap rsh61, or the larger rsh12?
Brighty
Pete Delaney
Get a very sturdy tripod and head... one that can handle more weight than you currently think you need....
Less wobble = better pictures and you may in future change your equipment and find you need a new tripod to handle the extra weight.
Pete.
Firstly is the redsnapper man enough for the 70-300?
Brighty
It's more than adequate for that setup (I use it for a Sony A850, Minolta 300/2.8 lens, vertical grip and flashgun) and that weighs an awful lot. I have the RS-283 tripod and RHS-12 ballhead and it's good for about an 8kg load. You're better off with the RS-12 as it's a heavy duty head, but it can be finely adjusted. A great combo BTW. If you have a TalkPhotography account (free), RS were doing a 10% discount for members, so worth sending an email to find out before you buy. Special Combo Package
jwramsay
Hi guys.
Brighty
I got all those lenses + 18-105mm
I also have the smaller ball-head and its fine.
Great tripod!
