Red tint via HDMI to Pio PDP 435XDE
hallabusa
If I connect my PC to the VGA input on the media box of my 435, everythings crisp and clear. However, going 'up' to the HDMI input (using a DVI to HDMI cable), everything seems to have a red tint (I've played with the settings on Power Strip which has helped a little, but even the overall picture quality seems very poor (far worse than scart!). When I receonnect my PC monitor (LCD), thereby using the same interface on the graphics card, everythings fine(using a DVI to DVI cable).
My PC is a P4 at 3Ghz, 1 Gig RAM, rADEON 9800 Pro card.
Any help greatly appreciated.
fusion7
ive got a 435XDE...its annoying how the VGA connector is at the front, so if you have a media center permanently connected it looks messy!
have u tried a different cable?
Joe Fernand
AVForums Sponsor
hallabusa
What signal are you outputting from your DVI equipped Graphics card?
Best regards
Joe
hallabusa
Fusion - no haven't tried a different cable - I'm suspecting my settings are to blame.......
Joe - my settings on the PC are currently 1280 * 1024, but when connected to the plasma my settings (profile) were set to 1280 * 720 with 32bit colour. I've used the .inf file which has been created for the XDE by another member of this forum - I'm also running Powerstrip (again on recommendation by reading previous posts - I've disabled this to see if it makes any difference, all to no avail unfortunately).
Cheers.
