Thx tried that still redHi.
Yes. I have had the same issue. Reseat your ram stick by stick. Your ram is not being recognised presently.
No beeps...Hey - your pc should beep at the start-up (post) - if something goes wrong at the basic level - these beeps should indicate what's up:
See here:
post beeps
hope it helps
f.
Umm dont see any LED display either, very strange it just broke unless my son was trying to overclock or somethingahh yes - sorry - on that MB you have the little display with two digits - that should flash codes and tell you what's wrong(at least in theory)
f.
