red horizontal lines top of screen
Discussion in 'General TV Discussions Forum' started by JoeyL, Aug 13, 2004.
  1. JoeyL
    JoeyL
    Hi all,
    I was just playing around with the different picture modes on my new Sony 32" (Smart, Zoom, Wide, etc..) last night, and I noticed that if you "scroll down" the image a little bit in the Zoom/Smart modes, reddish/yellow lines become visible at the very top of the screen - in the "black bar" area of a letterboxed DVD.
    These lines don't appear to be visible in normal TV viewing (if I don't scroll the image up/down), but I was wondering if this is something I should be concerned about, or is it normal to see this - scan lines maybe or something??
    cheers,
    Joe.
  2. JoeyL
    JoeyL
    anyone with advice at all?? :lease:
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Well, that's what happens when you go looking for trouble! :lesson:
    You were happy with the TV before, but now you're dissatisfied!
    I'm not familiar with that particular TV, but if you can't see the problem on a normal picture, I would suggest you forget about it.
    There are far more important things to worry about.
    Good luck. :thumbsup:
