red eye
Discussion in 'Satellite TV, Sky TV & FreeSat' started by aarons, Mar 28, 2003.
  1. aarons
    aarons
    advice needed installed red eye today but does not seem to work with qed roomlink ir repeater system.just like to know wetheri am doing something wrong or not compatible.has anyone used it with a repeater and having same problem.:confused:
  2. MikeHarrison
    MikeHarrison
    What remote are you using it with ?
  3. aarons
    aarons
    original ntl remote and one for all urc-7544
  4. MikeHarrison
    MikeHarrison
    This should work if things are set up like this :
    NTL remote in same room as STB (not through repeater)
    OFA set to code S0133 via repeater and Red-Eye
    Is this how you have set things up?
    Does the OFA remote/RedEye combination work direct (i.e. not through the repeater)?
  5. aarons
    aarons
    thanks a lot got it all working ok now.just had to read through instructions properly.
