Red blob being projected by Panasonic PTAE3000
Discussion in 'Projectors, Screens & Video Processors' started by mb3195, Feb 12, 2009.
  1. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    I've had my projector for around a month or so and am starting to notice more and more what I presume to be dust blobs appearing on my screen.
    At first this didn't bother me too much, but I've just finished watching Pride and Glory and have noticed a rather large red blob being projected on dark scenes.
    To be honest, I cant even tell you what the film was like as I spent the whole 2 hours watching this blo%^y red patch keep appearing.
    On inspecting my lens (after it was switched off), you can see what looks to be a red mark on the inside of the lens. It looks as though the heat of the bulb may have caused it.
    Does anyone have any suggestions on how I can get rid of it, or do I just call the place I got it from and tell them that I'm not happy?
    Any advice will be welcome.:lease:
  2. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,077
    +8,025
    If there is a red mark inside the lens, then you'll need to send it in for repair/replacement. A 'dust blob' tends to be on the LCD panel/filters and wouldn't be visible through the lens, though it is apparently not too difficult to remove with a can of compressed air/CO2 I don't think this will help you I'm afraid.
  3. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    4 weeks old.....RUBBISH!!!:thumbsdow
  4. jacko5
    jacko5
    Feb 16, 2007
    1,198
    63
    +173
    It is probably a dust blob. Get onto your supplier and report it as a defect. They will no doubt direct you to Panasonic. I would have thought that to have dust problems after a few weeks means that the dust got in during the manufacturing process, but whatever it's not acceptable.
  5. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    I've been onto Roy Jowett this morning and am waiting a call back. They initially said I have to send it to them, baring in mind I travelled 200 miles each way to pick it up, I'm not too keen on this idea so am waiting for a call back!
    Anyone had dealings with them before?
  6. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    Been messing around with the zoom and focus, it appears the red blob is actually a red fibre which has managed to get into the lens area.
    Can anything be done or does it need to go back to Panasonic to get sorted?
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Under retail law it is your responsibility to return the goods to the place of purchase at your own cost. It is the retailer's responsibility to arrange for the repair or replacement of the goods. You should not have to deal with the manufacturer at all, it is entirely the responsbility of the retailer to make all the repair or replacement arrangements with Panasonic.
    There is a lot to be said for buying goods locally.
  8. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    If only there was someone local I could have got it from!!:(
  9. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,077
    +8,025
    Just a quick thought: Try running the PJ in high altitude mode for an hour or so, this puts the fan at a higher speed and might dislodge the fibre. Hopefully it won't just move it to an equaly annoying position.
  10. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    After alot of chasing up, Roy Jowett finally told me to contact Panasonic directly!:thumbsdow
    Called Panasonic, they are arranging to pick it up hopefully tomorrow and get it back to be in 3-5 working days.:smashin:
    Told me it needs cleaning and was probably caused during manufacture.
  11. Speedoguy
    Speedoguy
    Oct 10, 2006
    1,485
    116
    Essex
    +638
    Great customer service there - NOT - beggars belief that in this financial climate you still get shafted around like this. Not a good advert :nono:
    Good luck with panasonic :thumbsup:
