Red banding
Discussion in 'Plasma TVs Forum' started by sniffer66, Dec 12, 2004.
  1. sniffer66
    sniffer66
    May 22, 2004
    9,870
    +3,605
    I have a Panny PW5 and have just started to notice a very pale band of red (approx 1.5")at the very top of the displayed picture. Its only visible on white or very light colours and then its only intermittent
    Its not that portion of the physical screen as it moves with the picture if I change the aspect ratio or letterbox 4:3.
    I'm feeding both dvd and sky via high quality fully wired scart to a Keene Scart to Component converter and then via QED scart to component cable into the Pannys component board
    Any ideas ?
  2. suicidal_maniac
    suicidal_maniac
    Dec 3, 2004
    58
    try removing everything apart for one source ie straight from your dvd player using one lead(also try swaping the one lead), if its still there try straight from some thing else...then try going in through another port...basically try and eliminate everything one by one...if you do all that and its still there it has to be something to do with the screen...good luck
