Red and Blue lines
Discussion in 'Plasma TVs Forum' started by TH-42PW6B, Jul 19, 2004.
  1. TH-42PW6B
    TH-42PW6B
    Help!
    I have used a panasonic TH-42PW6B since November 2003, after the screen has been on for a few hours the screen can start to distort and display moving/flickering red and blue horizontal lines, which I thought initially was just some distortion from a possible loose cable or some other interference. I have checked all connections and cables. If the screen is turned off momentarily then the problems goes away but can come back again within minutes or sometimes days/weeks.
    Any help greatly appreciated.
