Recovering Outlook Files
Discussion in 'Desktop & Laptop Computers Forum' started by Stellavision, Sep 11, 2007.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,488
    Portsmouth, UK
    +142
    Hi all,
    At the weekend I had a mobo die without warning on me and I had to carry out an impromtu upgrade.
    I have installed the old drive into my new system without modification so I can accesss some of my documents, etc on there. In particular I have email messages and addresses in my old outlook folder which unfortuantely are not all backed up in a .pst file. Is there any way to recover outlook files via windows explorer and drag and drop?
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    The last time you used Outlook will be contained in a file called personal.pst, just drag and drop this into the new folder that contains personal.pst on your new hard drive. Use windows search to look for the file, it should be there.
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,488
    Portsmouth, UK
    +142
    Thanks Andy.
    I just ran a search for personal.pst on the old drive but windows can't find anything.:confused:
  4. Bagger
    Bagger
    May 8, 2007
    2,225
    Leicester
    +227
    oldC:\Documents and Settings\[username]\Local Settings\Application Data\Microsoft\Outlook
    oldC:\Documents and Settings\[username]\Application Data\Microsoft\outlook
    copy the whole folder from these locations over the top of the new one which will be in the new C:
    Make sure you have show hidden files and folders selected from tools>folder options>view tab
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,488
    Portsmouth, UK
    +142
    Thanks for that. The problem I have now is that Vista won't let me copy files from my old xp drive to my new Vista drive.
    Its saying that I need administrative rights ehich I have.
    Knew I should have stayed with XP!!!:thumbsdow
  6. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    You need to add yourself to the permissions list.
  7. Stellavision
    Stellavision
    Apr 7, 2003
    2,488
    Portsmouth, UK
    +142
    Right, I managed to copy the folders accross. It successfully imported all email accounts but all my inbox sub folders are no where to be seen! :(
  8. Stellavision
    Stellavision
    Apr 7, 2003
    2,488
    Portsmouth, UK
    +142
    Sorted it now. Thanks for everyones input.:thumbsup:
