Recovering accidentally deleted emails
Mr_Wistles
Afternoon all,
I just had a big email clear out and now I have realised I deleted some important emails from Outlook 2003.
Is there any way to get these back? If I do a wind back via system restore will that put my email pst files back to pre delete?
Thanks.
vinny41
if you have previously backup your pc might be worth looking at your backup's for *.pst files which will be all entire mailbox once you have the file should be able to view the files as a new folder and then just select the emails you want to keep
Mr_Wistles
Been a while since I have done a backup!
Doing one now!
D
Deleted member 30535
And also set your outlook to leave emails on the server for a period of time before they get removed off the server.
That way you can always access your email from a web browser to get back to your last 14 days worth. Of course not much use if you deleted one of a few months ago! Depending on your email/POP storage and your email traffic, you may get away with much longer.
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
