Anyone else noticed a change in % required to record on sky+ recently. Not sure whether it happened when the latest software went on.
Previously 1hr recording seemed to use 6% ish
Now is less about 4%
Also when you first select an item to be recorded it tells you a required %, but when it actuallt records it is always less now.
Was recording a film last night at about 2 hours long, stated it wanted 11 or 12%, when i looked this morning, it stated that it had used 9%.
This never used to happen, just wondering whether sky had modified the amount or space used when recording an item, as had been mentioned on here previously ?
