Question Recording TV programmes
Status
Not open for further replies.
bluesa1
Hello folks,
Quick question please. Is it possible to use an old Sky box to record TV programmes when it is only connected via a conventional TV arial?
Many thanks.
grahamlthompson
In memoriam
That's a shame! Thank you for your answer.
Technically it probably is possible, but the kit to do it on a one off basis would run into thousands. The tuners in a satellite box are designed to work with higher frequencies than is used on terrestrial TV. In any case such a converter would need to connect the the lnb inputs. The rf input on a Sky box is merely used to pass on Freeview signals to the rf1 and rf2 outputs plus a single PAL analogue channel that allows remote viewing of the Sky box plus Freeview on a remote TV using a single coax cable, created internally in the box.
bluesa1
Very comprehensive description, thank you. It confirms that I can't use it as a recorder and it has also made my head hurt:thumbsdow
Status
JVC 4K projectors, Denon X3800 & Perlisten speaker reviews, adding a sub to 2-channel + AV/HiFi news
