Recording to TVR from old Panasonic
statto
I've got an old(ish) Panasonic camcorder [VHS-C] that has yellow and white AV out sockets on it.
I also have a shiny new Sony TVR19, and wondered how/if I can get my old VHS-C footage straight into the Sony. I imagine it might be via the S-Video socket on the Sony, but I can't find a cable that has yellow/white out jacks and an S-Video on the other end - or am I barking up the wrong tree entirely?
Stats
B
Brian110507
Yes - you won't get a cable with s-video connector on one end and composite on the other. You have two choices :-
1) connect the yellow and white leads from your Panasonic to the yellow and white connectors on your Sony
2) buy a composite to s-video adapter and connect that in the yellow lead - you'll still have to connect the white lead though and your picture won't be any better.
statto
Thanks BeeJayCee
It'll have to be an S-Video to Composite, as the Sony doesn't have white/yellow inputs, only a single yellow one marked "audio/video out"
Any idea where I can get hold of an s-vid/composite cable - I've had a search around on the 'net and can't find one.
Stats
B
Brian110507
You surprise me did you not have a lead supplies with your Sony with a single multipole pin connector on one end and the standard Yellow , Red and White connectors on the other ?
If you go to www.maplin.co.uk and search for product code WN78K you will see what I mean - did you not get one of those ?
As I said before your not going to find a lead s-video to composite you need a converter - you can find one here :-
http://www.keene.co.uk/cgi-bin/codesearch.pl?STOC
Don't forget that this will not transfer sound only video you still need to find a way to connect the white lead from the Panasonic to the audio in of the Sony.
statto
Sorry - numbskull mode - yes I did, but I've tried that following the instructions in the Sony manual, but unless I'm doing something wrong, it doesn't work.
Thanks for the info - I'll keep at it.
Stats
MarkE19
Are you putting the TRV19 into VCR mode when you try to record from the old cam?
Mark.
B
Brian110507
so - you have the yellow out from the Panasonic connected to the yellow of the Sony - and the white from the Panasonic connected to the red and white of the Sony. - - yes ???
when you play the video on the Panasonic connected to the Sony - with the Sony in VCR mode do you see your video on the Sony camcorder LCD screen ??
statto
No.
The Panasonic has yellow and white outs - the Sony has a yellow socket marked "audio/video out" (not in).
It also has an S-Video socket.
I have a lead (supplied with the Sony) with 3 way jack connectors on one end (yellow, white red) and a single black jack (with yellow concentric circles on it - if that' means anything) on the other end.
The Sony manual shows the A/V connecting cable for recirding video or TV (but I think that's only for the higher spec models that must have an audio/video in).
I's got firewire (obviously) but my VCR doesn't.
I'm beginning to think I'm scuppered, but I'd have thought there must be a way to get my analogue footage in.
I'll keep on trying nd looking
Thanks for your continued help/suggestions
Statto
B
Brian110507
statto
I thought as much - should have read the manual more thoroughly - not having a good understanding of AV ins and outs and S-Video & the like..........
Thanks fr the link - will follow up - and thanks for your patience with a newbie/idiot!
Statto
65-inch LG C1 Review coming soon to AVForums
