CadmannUK said:Hi All,
Is it possible to record from a Sky+ box out to a DVD, or copy a file to a PC?
Cad
Thanks - I was wondering what that was all about. ;-)JayCee said:Yes...that's what the Sky+ "Copy" facility does...outputs the progs from the HD in real time to the scart sockets and if you connect the outputs to a DVDR, VCR or PC you can record them.
It just plays the recordings full stop, doesn't necessarily have to be via the scarts, any output will do.JayCee said:Yes...that's what the Sky+ "Copy" facility does...outputs the progs from the HD in real time to the scart sockets and if you connect the outputs to a DVDR, VCR or PC you can record them.
This would depend on the settings you choose in the software controlling the DVR card.what file type does it export to PC in?
