Question recording temperature in the house
Discussion in 'Smart Home, Climate Control & Security Forum' started by rampant, Jan 31, 2018.
  1. rampant
    rampant
    Apr 24, 2006
    2,261
    116
    Sarf est near londoninium
    +885
    Hi all,
    so ive got my hive setup and working, its connected to my Amazon dot, so can control heating from there.
    What i would now like to do is to record the temperature in my house - i would like to get the data from my hive thermostat if possible - is there a way to do this? - i have several computers around my house.
    regards.
  2. Lesmor
    Lesmor
    Jul 25, 2007
    5,473
    2
    167
    Aberdeenshire
    +3,298
    Is the provided temperature history not adequate for your needs?
  3. rampant
    rampant
    Apr 24, 2006
    2,261
    116
    +885
    where do get the temperature history from? - ideally i would want to record the thermometor temperature, and then how long it took for the boiler to get the room up to the required temperature. Taking this data over time will allow me to see if ive got my timing and temps set correctly in the house.
    being a number-junkie i would also like to record this so that i can display over time :)
  4. Lesmor
    Lesmor
    Jul 25, 2007
    5,473
    2
    167
    Aberdeenshire
    +3,298
    Login to myhivehome.com
    From the dashboard select heating
    Scroll to the bottom of the page and you will get history options
    today, yesterday, this week, last week,this month, last month and this year
  5. rampant
    rampant
    Apr 24, 2006
    2,261
    116
    +885
    thanks! - learn something new every day!!! - however the data isnt very granular or intuiative - do you know if there is a way to download the information?
  6. Lesmor
    Lesmor
    Jul 25, 2007
    5,473
    2
    167
    Aberdeenshire
    +3,298
    Not that I know of
    Hive will send you a monthly report with your average temperature and how it compares to other Hive users in your area
    If you think the answers I gave warrant it consider clicking "best answer"?
  7. MikeHoy
    MikeHoy
    May 6, 2011
    161
    +43
  8. rampant
    rampant
    Apr 24, 2006
    2,261
    116
    +885
    thanks mike - doing some more digging it looks like i need to use something like Openhab openHAB . using this i can connect to bt hive servers and download the data from there....
  9. rampant
    rampant
    Apr 24, 2006
    2,261
    116
    +885
