Recording Sky to vhs!
Discussion in 'Sky Digital TV Forum' started by gazz81, Feb 9, 2009.
  1. gazz81
    gazz81
    Feb 2, 2008
    32
    An elderly friend asked if i could record a program for her that was being shown on the history channel on sky. I sky plussed it whilst I dug out my vhs to try and record it for her.
    So what I have done is connect the vhs via the rf out on the sky box. The vhs has been tuned to the correct channel and is showing a picture on a seperate telly that is also connected to the vhs via scart (hope this makes sense!
    The only problem is the vhs is only recording the sound and a load of squigly lines!
    I have checked the play back using a pre-recorded video and thats fine, so is it a problem with the recording side of the video or my connection!
  2. rigger2504
    rigger2504
    Feb 7, 2009
    39
    welwyn
    could be a problem with the rf, try conecting a scart from you sky box to the vhs. then select the av channel on the vcr.
  3. J4CK DANIELS
    J4CK DANIELS
    Aug 3, 2006
    1,483
    +231
    Some channels are encrypted with a protection system called Macrovision. you can always buy a 'powered' SCART if you want to record programmes on a regular basis....
  4. gazz81
    gazz81
    Feb 2, 2008
    32
    Its not something that I will probably ever do again! I have sky + so I dont usually have to record to another source.
    what I cant understand is that the picture I see on the telly is coming from the rf source from the sky box and through the vhs, so surely the picture I see on the screen is what the vhs should be recording?
  5. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Have you tried recording other programmes/Live TV?
  6. gazz81
    gazz81
    Feb 2, 2008
    32
    I only have the sky so I cant try using a terrestrial source. I cant seem to record anything from sky, be it sky plussed or live.
  7. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Are you sure the VCR is set to record from the RF input?
