recording rgb to hdd
Discussion in 'Blu-ray & DVD Players & Recorders' started by charlie55, Mar 3, 2005.
  1. charlie55
    charlie55
    Jun 27, 2004
    1,384
    Falkirk
    +102
    forgive me if this question has been asked before
    i want to record from a pace digibox to recorder(panasonice85) using rgb scart i have read that with sky+ boxs only output composite on scart. i was wondering if the same was true from an ordinary digibox. thanks :clap:
  2. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    All digiboxes output RGB from the "Tv" scart and composite from the "Vcr" scart.
  3. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    I would be very suprised if the sky box didn't output SCART RGB as this is one of the most common forms of connection to a TV.
  4. charlie55
    charlie55
    Jun 27, 2004
    1,384
    Falkirk
    +102
    does this mean i could connect the digibox tv out scart to the recorder and then out via component to tv. :hiya:
  5. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    Yes, connect the Sky Tv scart (with RGB enabled in the "picture settings" menu) to the E85 AV2 (also set to input RGB) and away you go. :clap:
  6. charlie55
    charlie55
    Jun 27, 2004
    1,384
    Falkirk
    +102
    thanks for the confirmation jaycee .many thanks :clap:
  7. Tellyfiend
    Tellyfiend
    Jan 21, 2005
    225
    +13
    Yes that's correct, just check you're using the TV scart (not the VCR one), different boxes have them different ways round.
    The downside of using the TV scart is that the Ext link won't work !
