Recording Ratio Query
Discussion in 'Blu-ray & DVD Players & Recorders' started by Miles, Dec 4, 2003.
  1. Miles
    Miles
    Having looked through the manual for my HS2 I found something that set alarm bells going..
    'Recording to DVDr can only be done to 4:3 ratio'
    Is this the case and does that mean I can't archive a widescreen presentation to DVD r that will show in correct ratio??
    It records widescreen correctly to the HD but I've yet to try to DVDr.
  2. DaveP
    DaveP
    Don't worry, it means that the picture is recorded in 4:3 ratio but it's squashed (anamorphic!).
    It works fine.
    Dave
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    The recording to the hard drive includes the switch to turn the tv to wide mode, once dubbed to -R the switch signal is lost. You just have to remember to manually select the tv mode.
  4. Miles
    Miles
    Ok, seems to be panic over!
    Thanks Guys
  5. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Although wide switching remains on a RAM recording
