Recording Raiders of The Lost Ark
Discussion in 'Blu-ray & DVD Players & Recorders' started by Shoom, May 11, 2003.
  1. Shoom
    Shoom
    May 11, 2003
    10
    Hi what whats the best settings and input for Raiders of The Lost Ark which is on BBC 1 at 6:10 today
    I have a new DMR-E50 :clap: and have read all the manual but not sure if I should use SP mode which is 120 mins on dvdr (the film is 110 mins long)
    Would using FR mode give a better picture quality ?
    Best input Sky or Aerial BBC 1 ?
    Thanks for any ideas you might have
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,241
    Warwick
    +2,282
    FR will give the better quality as it's going to use a very slightly higher bitrate. It'll be fairly neglible difference though and you may find it easier just to use SP (especially if your 'new' to the machine). Hows that for sitting on the fence :D
    That depends how good your aerial input is! I use Sky but that's because I have a rubbish aerial and can't be bothered to get a new one as I watch very few things non-Sky.
  3. ferris57
    ferris57
    Jan 18, 2003
    869
    I would use fr no question, also probably sky. But this depends on your arial. Personally I would use normal bbc1 but only because I get a very good picture and feel sky sometimes looks artificial.
  4. Shoom
    Shoom
    May 11, 2003
    10
    I went for FR mode 110mins on aerial bbc1 used the timer setup started spot on !
  5. Nobber
    Nobber
    Nov 29, 2001
    317
    The Box Set is out in November:D
  6. Party Animal
    Party Animal
    Jan 29, 2003
    241
    +13
    Everything was going great..recording it to my hard drive..then a huge thunder storm and the bloody picture broke up and dissapeared for about 4 minutes
  7. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Where do you live?
  8. encaser
    encaser
    Mar 15, 2001
    1,566
    Suffolk/Essex
    +112
    As Nobber sais, dvd in Nov'. Plus it was in 4:3 anyway.
  9. Party Animal
    Party Animal
    Jan 29, 2003
    241
    +13
    Where do you live?
    10 miles north of Leeds
  10. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    We could of done with some of the rain down here.
  11. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Yeah,a bit poor it was only in 4:3.Good picture quality though.
  12. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    Even though it was 4:3 and the DVDs are out this november, I still decided to record it on my E30. Just had to be done, :D Temple of Doom next sunday guys!!
  13. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    [​IMG]
    The above picture was of the start of the film which was letterbox, but it quickly zoomed into Pan & Scan.
    I recorded the mpeg transport stream from digital terrestrial directly into my PC using Nebula DigiTV so there was no anologue decoding/mpeg re-encoding, but it still looks pretty poor IMHO... look at these screen shots:-
    Another thing to consider, as with all BBC 4:3 material, it was transmitted as 4:3 within a 16:9 anamorphic frame, so it has half the horizontal resolution a of normal 4:3 picture. I had to stretch the screen shots out from 720 to 1024 pixels wide to correct the aspect ratio (that's what the set top box does, it reads the AFD code, stretches it out then it chops off the l/r border, see this document about AFD codes)
  14. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    Not on Sky digital it wasn't. Pure 4:3 on mine. Was yours imported from a freeview box? Just curious because of those 16:9 black bars on the left and right of your screen grabs. I would go as far as to say the quality of your reciever may not have been up to scratch judging by those screengrabs.
    But you should have recorded the analogue broadcast, it was infinately better.:D
  15. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Those screen grabs were made from playing back the mpeg file with Power DVD. It was not "recorded" from a normal freeview box (which decodes the mpeg stream into anologue video a bit like a dvd player), but it was from freeview. basicly the aerial connects to the card, and the card lets you view and record the raw mpeg stream using software decoding, normally this produces flawless mpeg files because they have not been altered, they are exactly as they were when they were encoded at the broadcasters end.
    I expect it was better on anologue TV in this case because of the lack of horizontal resolution when 4:3 pictures are transmitted by the BBC. The whole of BBC on freeview is transmitted as 16:9 anamorphic widescreen, and 4:3 pictures are squeezed into the middle of the 16:9 frame. The set top box stretches the picture out and crops the sides, so you dont normally notice the difference, but on the PC i'm looking at the actual MPEG data so you can see the difference. Other channels such as ITV use the mpeg header to change the aspect ratio so you get a full frame 4:3 picture when I record it.
  16. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    When you record from Sky using a DVD recorder or seperate Hard Disk recorder, what's happening is that the Sky set top box is decoding the mpeg stream into anologue video, goes down the scart cable, then the DVD recorder re encodes the video back into MPEG2. This is not loss-less and the picture will be degraded in the process.
  17. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    By that same reasoning viewing Digital via a scart to your TV would mean your TV is re-encoding the MPEG2 stream which is not quite true.
  18. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Uhh???? no it's not, the TV just displays the anologue picture that comes out the set top box (put very simply), there's no digital encoding inside a TV. I tried to explain it but i'm not going further into it. When Temple of Doom is on next week it should hopefully be in widescreen and i'll post a couple of screen grabs.
  19. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    But with the greatest respect, MPEG artifacts are always more evident and noticable when you are watching on a computer monitor.
  20. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I think I may have confused you a bit because I have both a set top box connected to the TV and the Nebula card inside the PC. Yes MPEG artifacts are easier to see on computer monitors because of their higher definition than TV sets, but I can burn the MPEG stream onto DVD using the DVD writer in the PC, and play it on the TV with the DVD player.
  21. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    I see. So you haven't yet viewed it on the TV then? Compared to how compressed BBC usually looks, I was pleasantly suprised.
  22. sr78
    sr78
    Sep 26, 2002
    281
    Hate to say this, but if it's 110 minutes, the BBC showed the censored version again... they do this all the time. I've watched all three Indy's on BBC at one time or another, and they always cut the more gruesome scenes (e.g. heart-ripping scene in Temple of Doom).
  23. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    I just gave up waiting for it on DVD and bought a laserdisc player :)
  24. sr78
    sr78
    Sep 26, 2002
    281
    Then I hope you didn't do that too recently, since they'll be released on DVD as a box set in December :)
  25. Shoom
    Shoom
    May 11, 2003
    10
  26. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    Raiders was shown UNcut this time. Temple will probably be shown with the BBFC cuts made. (like the UK DVDs will be) Last crusade was more kiddie friendly anyway, and probably uncut.
  27. sr78
    sr78
    Sep 26, 2002
    281
    Even the DVDs will have the cuts? Why??????????????? So they can slap a PG label on it?
    Thank god for DVDboxoffice.com :)
  28. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Raiders on BBC last week was exactly 1hr:10mins:10secs including credits.
  29. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,416
    North East Scotland
    +65
    No way, dude! :eek:
  30. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    Don't you mean 1 hr and 50 minutes ;) Or about 110 minutes
