Recording R0 dvds
Discussion in 'Blu-ray & DVD Players & Recorders' started by thesource, Nov 2, 2001.
  1. thesource
    thesource
    I have recently bought a 'Macrovision Video Stabilisor' from www.sonel.com.
    Although the product works when I record R2 dvds, it records in black and white when I record R0 dvds...
    Why is this?
    Can anyone help?
    Please???!!!
  2. mjn
    mjn
    May 24, 2001
    23,245
    Herts, England
    +11,498
    becasue R2 are PAL, and R0 are usually NTSC
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,576
    Somewhere in South Yorkshire
    +6,097
    What are you recording on? What DVD player are you playing on?
    This is probably about video signal standards, rather than regions. If the R0 DVDs of which you speak have an NTSC signal on them, and your VCR(?) can't handle NTSC, then this is the problem.
    First, you can try setting the output of your DVD player to PAL. If this gives you a usable result, OK, but note that in all probability, the tape will be recorded in an unusual way (PAL525/60) which is only used in Brazil, I think, and may well be unplayable on other machines.
    Otherwise you will need either a DVD player with the ability to output true PAL/625/50 from an NTSC disc. Very few do (including some Samsung models). Or a digital video standards converter (Lektropacks, prices from £200-£850). If the latter, it will probably do away with the need for the "stabiliser" you have.
  4. thesource
    thesource
    Thank for the quick replies guys...
    My setup:
    SONY 335DVD Multi Region
    Connected via - Macrovision disabler
    to...
    SONY Video
    connected via - scart
    to...
    SONY 32" Wide 50hz
    When playing back any DVD the picture is fine.
    When recording R2 DVD's to VHS the playback (from newly recorded tape) is in colour and fine
    When recording R0 DVD's to VHS the playback (from newly recorded tape) is shaky and B+W
    Is there a setting on the DVD or Video that needs changed to make R0 recording/playback better???
    Thanx again
  5. LV426
    LV426
    Jul 14, 2000
    13,576
    +6,097
    Please re-read my response. Now you've added "shaky" to your question, this reaffirms that the problem is with your R0 DVDs being in NTSC format, whereas your R2 DVDs are in PAL.
    You'll get the same symptoms with a R2 disc from Japan - they are NTSC like R1 is, and like MOST R0 titles. You'll need a standards converter or a suitable DVD player, or a multistandard VCR.
    You simply CAN'T tape an NTSC video signal on a regular PAL VCR.
  6. thesource
    thesource
    nigel,
    thanx again for the response...
    When i say shaky, I mean there are lines running across the width of the screen during video playback.
    Other than these the picture is fine, only in B+W...
    My TV can handle NTSC, so can the video and DVD,
    So why the problem converting the images from DVD playback to VHS?
  7. mjn
    mjn
    May 24, 2001
    23,245
    Herts, England
    +11,498
    no, your video can't handle NTSC, it can only PLAY, and NOT record!!
    You need to have a video that has NTSC record facility, or a DVD player that can output true PAL!!!
  8. thesource
    thesource
    thanx for all your help guys... appreciate the knowledge.:p
  9. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Your VCR might have NTSC playback facilities but most likely no NTSC recording function.
    Only a very few European VCR models support NTSC recording.
