Recording pre-recorded VHS onto DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Miles, Oct 1, 2003.
  1. Miles
    Miles
    Is it possible to record pre-recorded VHS tapes onto DVD on a standalone DVD Recorder? If there are copyright protection issues are there any technical ways around this?
    I have several stand up Comedy VHS tapes not available on DVD so I wanted to tape them to DVD so that I wouldn't have to bother with clanky VHS anymore.
  2. yatesd2404
    yatesd2404
    I think this should work, note I say think as I started this morning before I left for work copying my original Star Wars trilogy tapes as want to get rid of last remnants of VHS.
    I did a quick test and it seemed to be working, but will be able to tell you more when I get home to confirm that the whole thing completed succesfully.
    Will post later when I get home.
    Dave.
  3. andymc
    andymc
    Sep 18, 2003
    261
    Bedford
    +15
    I have been copying some VHS onto DVD+R/RW and had no problems so far using a Philips 880 recorder.
    Dont go lower than the LP mode though as picture quality falls drastically.
    Not encoutered any "Copy Protection" problems
    Andy Cuthbert
  4. yatesd2404
    yatesd2404
    Worked fine last night on my HS2. A little dissapointed in the picture quality but I think that is simply because I had forgotten how bad VHS was. Crap in Crap Out I guess.
    Cheers,
    Dave.
  5. MATTHEW
    MATTHEW
    certain vhs videos are copyright protected and won't record on to DVD.My Star Wars trilogy being a good example.
  6. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    A KT Vision Scart will remove any copy protection,Macrovision from VHS and also CGMS from DVD-although some say this is on some VHS too.Any VHS that copies direct with no problem will not be protected
  7. yatesd2404
    yatesd2404
    My original Star Wars trilogy worked no problem!!
    Dave.
  8. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Anyone know where one of these KT Vision Scarts can be got from?
    Panic
  9. phelings
    phelings
    Jul 24, 2003
    1,025
    36
  10. yatesd2404
    yatesd2404
    As I said I use a normal RGB Scart and I none of my original VHS tapes have had any problems recording direct to my Panasonic HS2.
  11. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Then one must assume that Macrovision has been disabled along with the multiregion hack.Thats usually the case anyway.
  12. yatesd2404
    yatesd2404
    I have a standard shop bought version without any multi-region hacks, so not sure about why it works without a problem.
    Dave.
  13. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    That is unusual,and is not the norm.One could always try to copy before getting any special leads.
    The above lead will allow dvd-dvd copying
  14. jeff-f-100
    jeff-f-100
    Can I just check this out please...(location UK)
    Trying to archive some imported US NTSC VHS tapes onto PAL format Panasonic DVD, (UK PAL VHS machine can also output PAL signal from NTSC tapes) but keep getting 'interference' and black line along bottom - am guessing it's from Macrovision or similar.
    Will a "smart" scart eg from KT Vision mentioned above, (or is there anything else) cure the problem and if so - which version do you think I should get??
    Many thanx
    jeff
