Recording on satellite tv......
Member 114166
Can someone give me the options on how i can set a timer to record tv from a aftermarket digital receiver box, ie.. skybox F3, openbox and those alike?
Currently i pay for the full package with sky for the last 6 years, looking to get rid and was wondering if i can use the original sky box to piggy back off the skybox F3/OPENBOX.. to record?
If not what are my options?
Appreciate your input
kevkbuk
You can't link them for recording, you could only do that if you got a PVR instead.
The open boxes don't do the 7 day epg, only now and next. You can record to a USB hd but will have to setup manual timers. Much better would be to replace the Sky box with a Freesat reciever such as the Humax Foxsat Hdr that has full 7 day epg and allows series linking and epg based recordings the same as Sky but with no ongoing subs.
logiciel
The usual option is a Freesat PVR: freesat+ HD TV recorder - freesat.
There are very few of those to choose from, but there are plenty of what are usually called generic satellite receivers with either internal or external drives for recording.
The Sky machine isn't involved in any of that.
It may still record the free channels though, and there's always the option of connecting it to a DVD or BR recorder and leaving it on the channel you want to record.
Member 114166
Thanks guys,
Already purchased a F3 box, dont really fancy keeping it on the same channel for recording purposes. A USB external hdd you say may do the trick? would i need to load sme kind of software on it first? or?
logiciel
It records to an external drive in an enclosure or caddy and connected by USB, and should do that simply by pressing the record button or setting a timer from the EPG.
Member 114166
Okay, and you need not anything else? plug hdd in, press record on the desired channel and it will record? no fiddling with settings/software?
logiciel
That's what you do with most machines and this one has a Record button - link - so it looks like it's the same.:thumbsup:
You'd probably need to format the drive first by using an option in the machine's menu system.
