Recording on my PC using the Sky HD Box.
Shane
Hey...
Until now I've been using a TV stick on my PC to record some programs and then use VideoReDo to cut out the adverts. Now I want to start recording from my Sky box (running out of space!! :(). I use the HD PVR and plug the Sky box into it via the yellow, red and white cables but once the file is recorded, VideoReDo will not open it. I used MediaInfo to have a look at the file type and it's a MPEG-TS file.
Just my luck, VideoReDo doesn't support the file type. Are there any programs I can use to convert the file back into MPEG2 so I can use VideoReDo to cut out the adverts.
Or if there's any other programs you would suggest, please let me know.
Thanks.
P.S. I have used Google already. :p
