Recording NTSC Broadcast
Discussion in 'Blu-ray & DVD Players & Recorders' started by inabsentia, Sep 10, 2004.
  1. inabsentia
    inabsentia
    May 18, 2004
    27
    have a motorised satellite system and I occasionally want to record from a US based channel which is in NTSC.
    I have a worldwide standards VCR which does the job fine, but I'm moving away from tape based recording as much as I can now.
    My DVD recorder is an LG DVR 4810..it handles NTSC just fine on playback, but when I try to record, I don't get a watchable picture. I'm recording via the composite inputs on the front panel which is connected directly to my satellite receiver by scart.
    I'm sure NTSC recording is possible with this machine..I know you cannot mix PAL and NTSC on the same disc, but I'm trying to use a brand new, fresh out of the wrapper DVD-RW.
    Anyone got any thoughts?
  2. Delh68
    Delh68
    Dec 13, 2002
    1,046
    48
    +53
    Do u have to select a menu option that allows u to record in NTSC, rather than PAL, i'm pretty sure that is the case with my Panasonic E55, may be a similar case with the LG ?
    If all else fails, u could try the manual (lol)
    Delh68
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
