Recording not completed "Disk Full"
Discussion in 'Blu-ray & DVD Players & Recorders' started by panaman, Nov 30, 2004.
  1. panaman
    panaman
    Nov 17, 2003
    295
    Hampshire UK
    +14
    Hi I had the above "Disk Full" error the other week on my Panasonic E50 recorder and after checking, realised that I had set the timer earlier in the day and forgot to put a new disk. The disk in the recorder was full, so I can understand why I got the message.
    But.....
    Yesterday I took delivery of my new Panasonic E85, which I am really pleased with, but still getting used to.
    What happened is that I set a timer recording to the HDD and it started and completed ok, but when I turned on the TV and hit the Navigator button, I got the message "recording could not be completed - Disk Full" As the program was only an hour long, recorded in SP and had a totally empty disk, I was puzzled. Funny thing is the recording was there in its entirety :thumbsup:
    any suggestions :lease:
    PS still getting used to the recorder doing things without me knowing it. By that I mean on the E50 when it was recording you would see the power light come on and the little red circle would be rotating, channel number showing etc.... but on the E85 all you see is the little red REC indicator, no power light, channel number or anything, unless you press the Navigator... wierd, but I will get used to it :)
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Do you need to select the HDD before you hit the Navigator button? You may be seeing the message left over by the DVD.
  3. panaman
    panaman
    Nov 17, 2003
    295
    Hampshire UK
    +14
    By that do you mean did I press the HDD button on the remote before I pressed Navigator?...... that is something I can not tell you :blush:
    So..... maybe from that comment I was still on the RAM navigator and could have been the reason why I got the message, because it thought I was trying to access a recording from RAM :oops:
    Thanks.... I think :)
  4. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Doesn't the E85 have lights on the front showing which disk is currently selected? Pioneers have blue for the HDD, yellow for the DVD.
    Attempts to use Navigator for an empty DVD drive produce a 'No Disk' message.
  5. HMHB
    HMHB
    Nov 11, 2001
    26,865
    Nottinghamshire
    +5,653
    Yes the E85 has lights on the front so you can see which device you are using - blue is the hdd
  6. panaman
    panaman
    Nov 17, 2003
    295
    Hampshire UK
    +14
    Yes it does as you say, so I guess I must have had the navigator on DVD instead of HDD :oops:
  7. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    If the dvd is set to record and is full or missing from the drive, it will record on the hdd instead, called relief recording.
