Recording my SKY+ recordings in RGB via the vcr out scart terminal
Discussion in 'Sky Digital TV Forum' started by fuzzybee, Oct 21, 2005.
  1. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    I have a dilema, recently i purchased a Panasonic DMR-ES10 dvd recorder to copy some sky+ recordings i want to save. After setting it up how the manual states with the vcr output on the sky+ box going into the relevent socket on my dvd recorder and setting it up to accept a RGB signal i only get composite recordings.
    My sky+ box (pace) only sends a composite signal out of the vcr output, i cannot find any settings to change this to RGB am i missing something or is this how it is.
    I have remedied this by connecting my sky+ RGB output which initially went straight to my plasma to the dvd recorder first.
    Then the relevent output on the dvd recorder to the plasma, i can now record sky+ via RGB on my dvd recorder, daisy chaining it in effect.
    Now does everybody do it this way or do i need to set my sky+ box to output RGB through the vcr connection.
    Can anybody help and put me out of my misery :lease:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Alas the VCR scart is composite only, I suppose it saves SKY a few pennies per box but times have changed and for some having two RGB outputs would be useful.
    Daisy chaining as you have discovered the practical solution and I suspect used by most DVD recorder owners:)
  3. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    +72
    Thanks for the quick reply starburst, i can now rest easy knowing i did it right
    :smashin: thanks mate :D
