Recording Movies on Channel 5 with Sky+
Discussion in 'Sky Digital TV Forum' started by moz414, May 10, 2005.
  1. moz414
    moz414
    Apr 13, 2004
    583
    Chippenham
    +11
    I set the planner to record a film which has a news break in it and it only records the first part of the film! This happens mainly on Channel 5 but also on ITV as well. What's the point of having a planner to record a movie when I have to set it twice? You'd think that sky would recognise that it's the same movie. Has anyone else come across this problem with Sky+?
  2. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    I think you are meant to do series link with films on C5.......sorry, re-phrase that.... if you do series link it works.
    You're right, it should be working properly.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    SKY have no say in how Five structure their EPG data.
    SKY+ relies on the EPG and Five give the news/weather break (within a movie) an EPG slot which makes the movie into two parts. They supply a series link to allow the SKY+ to automatically record both parts, something new users always learn about the hard way:)
  4. moz414
    moz414
    Apr 13, 2004
    583
    Chippenham
    +11
    Thanks for the replies, I will try using the series link feature.
  5. DaveP
    DaveP
    I prefer to do a manual recording in this situation. If you just record the movie and leave out the news you are quite likely to miss a bit of the movie.
    Dave
  6. Cynthia 7
    Cynthia 7
    Hi Moz,
    I've been caught out a few times on different channels with a new break. It's so maddening.
    Hi DaveP,
    That makes sense, I will remember to do that in future; I would normally just record before and after the news. Nowadays I set the planner to record five minutes before the programme starts and continue for ten minutes after, I have so often missed the end previously. It can cause programme clashes when recording two different channels at the same time doing that overlap.
