Recording Is blurry and blocked on Samsung DVD-R155
A
AHAYNES316UK
Please help, when recording off sky, especially football and wrestling the recording is perfect for a few seconds then blocky and blurry for a few seconds and it keeps doing this all the way through the recording, i have my setup all done thanks to this forum and the picture when watching sky is perfect, can anyone help ??? :lease:
hi its the recording setting you are using the more data on the disc the worse the picture is it sounds like you have got it on the 4hr record setting
A
AHAYNES316UK
Im using good quality dvd rw discs and have only put 2 hours of recordings on there, (was hoping to put more) but it does it right from the start.
A
AHAYNES316UK
Most the programs i want to record are around 3hours long, so if i do the 2 hour option its ok, and for the 4 hour its poor, any ideas, are the special discs you can buy ???
