Iskren
Hello,
I've got this old camera or camcorder might be a bit more accurate (I'm not into cameras too much so sorry), it's the JVC GR-D270 and I want to get the videos from it onto my PC. I searched around and found this tutorial Two Ways To Transfer Mini DV Tapes To Computer. - VHS CONVERTERS. There I found that I need a Firewire card. Fair enough, I got one and installed it. Then I installed the MAGIX software because the guy in the tutorial is using it. I've connected the camera to the Firewire card with a mini-DV cable and I'm following the steps in the tutorial. I choose a name, I choose location, etc. But when I press record.. it's black. And no data seems to be written at all as the file size is at 0. So then I stop recording and here's another thing, the file ends with .avi.H0 and has a size of 0 bytes. The camera is indeed in playback mode and you can even see on its little screen that the video is played. I can use the playback controls in the MAGIX software just the way I'm supposed to and also if the camera mode is changed to the one which is used to shoot, you can see the camera output in the MAGIX software's preview. I have updated the driver for the Firewire card and I don't see a reason for this to not work. Have you guys got a clue how to fix this? I've got a lot of videos on these old cassettes and it would be great if I can get them out of there before it's too late.
