Recording in the rain
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by niccam, Aug 15, 2005.
  1. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Hi I was wondering has anyone any tips on recording in the rain My main problem is the when using a rain cover to keep the camera dry is that the mic is picking up the sound of the rain drops on the plastic cover.
    How waterproof is the mic if the mic is kept out from under the cover?
    I do have a windsheild can I put a plastic cover under the mic windsheild?
    Has anyone any thoughts on this subject . Thank you
    The camera is the Canon XM2
  2. Roy Mallard
    Roy Mallard
    a rycote windjammer will not be waterproof but for short spells the water should wick into it rather than into the mic. make sure to dry it out (and have some silica gel in you kit bag.
  3. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Try and get some distance between yourself and the subject (use a radio mic if you can) then optically zoom (gets as many rain drops between you and the subject as possible) and try and light the raindrops up - one of those powerful torches works well if you hit the right angle.
  4. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    LOL. and thanks Roy like the idea of the silica gel so simple but so effective
