Recording in composite & RGB?
S
Shin Gouki
If you record in composite and playback in RGB is the picture quality totally composite?, or is it like a mixture of both composite and RGB, considering that you recorded in composite and played it back in RGB? :confused:
Do you still get lip sink problems on a sky/telewest/NTL box if you watch something in composite and record it in RGB at the same time? :confused:
Is it possible to watch in RGB and record in RGB at the same time without any lip sink probelms? :zonked:
Kevo
You will get composite ONLY on playback.
Sorry, you've lost me on the lip synch problem.
Can you clarify what make and model and what problem you are having
S
Shin Gouki
I'm not having problems with any model because i don't own one yet. :laugh:
I wanted a panasonic machine but not any more, after the amount of people who are moaning over the lip synch problem that you get when trying to watch SKY/telewest in RGB and record at the same time in RGB.
I suppsoe i could record in RGB and watch in composite? :(
Why can't they just invent a machine that works? :rolleyes:
Yuccaman
Shin - Many Panasonics will experience the problem if you are watching what you record.
You always want to record in RGB, not composite....
There are 3 ways around this:
1 - Watch from the second output - For Sky, this will be composite. For Sky+, you could use the SVideo output & connect to your TV if the TV can accept SVideo - better than composite.
2 - Whilst recording, effect a timeslip, so in effect you are watching TV about a minute behind schedule. The lip sync problems will not appear.
3 - Don;t buy a Panasonic... Seriously, I *think* the E100 doesn't have this issue. My HS2 does, but I hardly ever record a progam that I am watching live, so I knew about the issue but it didn;t matter to me.
S
Shin Gouki
Silly me :blush: , i forgot about the timeslip fuction.It would'nt bother me to watch what ever i'm recording about a minute later.
Thanks for reminding me about the time slip. :thumbsup:
PS,
Is there a time limit on when you can start to watch a program that you are recording, or can you start the timeslip proccess, let's say, 10 seconds after you first begin recording? :confused:
kenfowler3966
Its not a minute later you can get as close as 7 seconds behind and not suffer the lip sync problem, but still close enough to deal with the red dot, if you are watching whilst you record.
Podcast: REL T9/X Subwoofer + Bowers & Wilkins PI7 Reviews, AV Shows in a Pandemic and more
