Recording from Viera Freeview tuner
Discussion in 'Plasma TVs' started by adrianl, Nov 16, 2004.
  1. adrianl
    adrianl
    I know this has been asked before but searching all the replies stil leaves a couple of questions!
    Have E85 and Viera on the way (thanks JL). Currently record freeview from sony 800u box to E85 AV2. I'd like to connect the E85 to Viera via component, and then send audio over AV4 scart on Viera.
    But I understand the viera dvb can be routed to AV4 to record freeview. If I wanted to do this will the E85 record via a scart from its AV1 to Viera AV4 if latter is Qlink-enabled? In which case is AV4 set to rgb or s-video or what since the E85 only has rgb input on its AV2 scart according to manual?
    If you connect the E85 to record viera Freeview using E85 AV2 scart, then does this mean you have to send audio from E85 to an A/V amp via separate cable?
    Thanks in advance for enlightenment,
    Adrian
