recording from sky
Discussion in 'Sky Digital TV Forum' started by markbigears, Dec 30, 2004.
  1. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    Possibly a nob question but what the hell I can't figure it out....so iv'e got
    my sony 750 box up and running with my free to view card. What I dont see is how to program the VCR to record programs? I mean like VCR plus codes.
    Iv'e looked at the EPG, but again no help. Anyone?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    You mean you want the VCR to control the digibox (channel changing etc) ?
    Well some VCR's had sat control (via IR) which could control the digibox, it yours isn't one of them you may have to rely on the digibox Autoview system which should turn the STB onto the right channel and in some cases signal the VCR to start recording on the AV channel, barring that you should use Autoview in conjuction with manually enter VCR recording times.
    Not much experience in this area to be honest, had a totally reliable sat control VCR (well apart from the times I entered the wrong numbers) and then went onto SKY+ which makes using a VCR for recording seem like the stone age:)
    Might be worth taking a look at the Phantom PVR.
  3. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    what i ment in a round about way is for example: record eastenders at 7pm on thursday.......how do you do it?
  4. JayCee
    JayCee
    Jan 20, 2004
    19,786
    Lanarkshire
    +1,882
    I would'nt do that. That will break it! :laugh:
  5. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    The normal video plus codes work, the only thing is you will have to change the channel number to that used for the STB (AV?) after setting the video plus number. On some VCRs you can specify that satellite channels always use a predefined input (no help with BBC).
  6. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Basic method...
    On the digibox, set Eastenders on Autoview from within the Planner and manually set the VCR timer for the published timeslot and AV input. The VCR manual should tell you how to do this including which AV input is assigned to which scart socket. Don't forget to connect the digibox VCR scart to the VCRs input scart with a scart cable:)
    IF the VCR can be triggered by commands sent over the scart cable when the Autoview is activated then that would be more practical but this feature is not common/reliable.
  7. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    many thanks guys for all your help!
