recording from SKY+
Discussion in 'Sky Digital TV Forum' started by deepblue2uk, Nov 15, 2004.
  1. deepblue2uk
    deepblue2uk
    Hi guys i have recorded a program on SKY+ but want to keep it. I no longer have a video recorder and haven't yet purchased a DVD recorder. Can i use my PC to record the program from SKY on to a Blank DVD?
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    I'm unaware of anyone having done this. If you haven't yet enough dosh for a DVD recorder and are unable to record via PC you could maybe buy a new HDD and swap it out, keeping the old HDD in a box somewhere until you have a DVD recorder.
  3. mps
    mps
    Oct 16, 2001
    1,502
    London
    +52
    Yes you can provided you have the necessary equipment.You will find all the answers at www.dvdrhelp.com. :thumbsup:
  4. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Yes, you could buy something like the ADVC-100, but that's £200 and a hassle when you can buy a decent DVD recorder for not much more.
  5. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Deepblue
    If you just want to do this as a one off, then get yourself a budget spec video capture card, around the £30 mark. This will let you use your PC to capture the video and is a good introduction in to PC recording/editing. If you find it suits your requirements then you might find that you dont bother with a standalone DVD recorder, which while more plug and play than a PC, it cannot match the control that a PC gives for editing purposes.
    cheers
  6. dagger
    dagger
    Jan 23, 2002
    262
    sussex
    +15
    yep - very easy with a capture card :thumbsup:
